I've rented about 15 DVD and own about 10 of my own, and all the DVDs will play.
Yesterday I rented the Gandhi DVD from the local library, and it won't play.
The player just sits there. It doesn't auto-play.
I finally pushed the PLAY button, and then the menu comes up. But I can't access any of the menu choices. If I push the PLAY button again, the video freezes.
I've turned the unit on and off. I've tried re-seating the DVD in the tray. I even tried wiping the DVD with a soft cloth. Nothing works.
Any idea what is happening.
This is called non violent civil disobedience. It will eventually cause the dvd to split into two regions but only after much relocation and bloodshed.
Originally Posted by RabidDog
Anyways ...
Is it just the GANDHI DVD that is giving you trouble? If so you did say that it was a rental correct? My guess is it just got scratched up from being rented so much. Only thing you can really do is try to clean it ... even if it already looks clean ... and try again.
DVD won't play
By BLSAMPLES in forum Newbie / General discussionsReplies: 5Last Post: 24th Sep 2009, 22:20 -
DVD will play on new DVD player, but won't play on old
By joe8915 in forum Video ConversionReplies: 9Last Post: 18th Feb 2008, 18:57 -
DVD Won't Play
By gumdoc in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2007, 19:10 -
DVD won't play
By Golgo13 in forum Newbie / General discussionsReplies: 4Last Post: 19th Sep 2007, 15:40 -
one particular DVD won't play on my PC
By moe_b_disc in forum Newbie / General discussionsReplies: 3Last Post: 2nd Sep 2007, 05:20
