My Pionner 525 don't show timecode on display when i use a DVD authored on MAESTRO. In menu shows "MENU" (all right) but during the film the display shows "PLAY". Is there some options in MAESTRO to activate the timecode. Thanks
On your pioneer remote try pressing button 1 rather than the play button.
Discs made in DVDit! but not burned in DVDit! will do this on my Toshiba. A fluke that exists in certain circumstances.
I know now what happens! In DVD MAESTRO, if i set , in movie properties, the NEXT and PREVIOUS settings to go back to MENU, this thing happens in my player. I have to set the last chapter's END ACTIOn back to MENU to works. For some reason, if you set the movie to play in loop or linked (with next and previous to something) i can't view the timecode in my standalone player.
This may have something to do with the fact that movies that are authored using multiple VTS's/PGC's can't do a time search. Does the main feature spill over onto more than 10 VOBs? Did you merge (concatenate) 2 or more movies? Is your menuing/branching really complicated?
If any of these are true, that's probably the cause of it, and it most likely won't show timecode in ANY DVD player then.
If I'm barking up the wrong tree, then forget what I said.
Subs don't show properly I don't know what to do
By atai in forum SubtitleReplies: 1Last Post: 8th Oct 2009, 07:44 -
My DVD don't show the picture, time line and subtitle on DVDSubEdit
By larrycenter2006 in forum SubtitleReplies: 3Last Post: 21st May 2009, 22:11 -
Need timecode display movie for debugging
By cybertheque in forum Capturing and VCRReplies: 6Last Post: 23rd Oct 2008, 16:19 -
DVD TV Show menus don't function
By Krispy Kritter in forum DVD RippingReplies: 7Last Post: 2nd Jan 2008, 11:35 -
Made in India Verbatim DVD blanks finally show up in Canada
By oldfart13 in forum MediaReplies: 13Last Post: 3rd Dec 2007, 16:35
