I have been having problems with all the programs I have tried while editing MPEG2 files. I have tried using Video Studio 6, TMPGE, and Womble MPEG2VCR and a few others I can't remember. The main problem is that they do work for a few files, then stop working after that.
Womble worked best and did exactly what I wanted. Unfortunately it only worked perfectly for 4 files, now the sound goes out of sync until it goes to silence while the video keeps playing. The similar thing happened with TMPGE but the video went too fast. I thought this may have just been a problem on my PC, so I tried it on a computer that Womble was working fine on, and it was doing the same thing as well.
I also tried uninstalling and re installing the programs, and it didn't help either.
I then thought it may have been a problem with the MPEG2 file, so I captured it again and the same things happened.
Why do all PCs hate me?![]()
Any ideas what may be the problem? What is the best output when saving in Womble? There are about 3 MPEG2 settings there.
Grenge
"Don't look at me. I'm irrelevant." -
It may be the file itself may be in a corrupt state on the FTP site you got it from.
Hello. -
Do you mean the Womble install file?Originally Posted by Tommyknocker
Seems strange that the program worked fine the first few times.Grenge
If you change the settings in Womble it changes from an editor to an encoder.
m4a editors?
By bat999 in forum AudioReplies: 17Last Post: 7th Apr 2011, 10:33 -
good editors? free?
By sboarder2011 in forum Newbie / General discussionsReplies: 8Last Post: 6th Oct 2009, 15:30 -
video editors
By aruwin in forum EditingReplies: 0Last Post: 16th Aug 2009, 00:31 -
going crazy with editors
By ellabbs in forum Newbie / General discussionsReplies: 1Last Post: 28th May 2008, 11:06 -
mp4 editors... are they available?
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 4th Feb 2008, 02:02
