just want to know if the trial version is completely unlimited or handicapped. I know a lot of software will limit you to a certain file size or something similar when using a trial version. If the only limitation is the 30 day period then I'm good to go for testing this on a full DVD.
Yes, I think the 30 day limit is the only limit one the trial version (only 30-limit on mpeg-2 encoding).just want to know if the trial version is completely unlimited or handicapped. I know a lot of software will limit you to a certain file size or something similar when using a trial version. If the only limitation is the 30 day period then I'm good to go for testing this on a full DVD.
Good luck with your "full DVD" project then!
10110101100111012011 <- The bug Bill doesn't talk about. -
thanks thats what I needed to know
TMPGEnc DVD Author question/
By ingeborgdot in forum Authoring (DVD)Replies: 11Last Post: 22nd Sep 2008, 14:58 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 14:25 -
TMPGEnc MPEG Editor 3 Trial (English version) available!
By gyoshi in forum Latest Video NewsReplies: 2Last Post: 6th May 2008, 10:25 -
Can't open older TMPGEnc DVD Author files in latest version
By steelborn in forum Authoring (DVD)Replies: 1Last Post: 19th Feb 2008, 14:55 -
TMPGEnc Author Version 2.0 - Unable to make a DVD with a motion Menu
By tug_hill2 in forum Authoring (DVD)Replies: 5Last Post: 28th Sep 2007, 01:37
