forgot about the filter, sorry about that.
Thanks DJ, but I love TMPGEnc.![]()
Results 31 to 41 of 41
Since DJ told me he was getting confused, I've added some comments to my initial post. I hope now everything is clear.
DJ: I tried to reply to you PM, but I think the PM was not sent. -
Its ok, i got the PM, thanks, all sorted now!Originally Posted by pladeira
How do you advise me it's batter to convert form an *.avi (pal) to an dvd ntsc...:
a: *.avi(pal)-->dvd files (pal)--> dvd files (ntsc)
OR
b: *.avi(pal)--> dvd files (ntsc)
P.s. If i have dvd files in pal can i get them in dvd files ntsc??? How???
10x -
If i have an *.avi file in pal and i need an dvd in ntsc from it how can i do it? Tell me a guide also pls....
10x -
You need NANDUB (for video) & BESWEET (for audio).Originally Posted by voicu_n
You have to extract & convert the video and audio seperately.
VIDEO & AUDIO extractions
In NANDUB, open avi, goto file > sav wav.
Now goto audio tab, select NO audio, goto video tab, select framerate, and change to 23.976FPS, then Save avi.
video and audio is now seperate, but audio is still 25fps, so:
Audio FPS conversion
In BESWEET, load up all settings, besweet.exe, ect, ect......
Now Load ur WAV file which u extracted with nandub, on the left select the "Change FPS from 25000 > 23976 or use one of the presets, hit 2Lame tab on right, and select wot output mode u desire (Dual channel (surround sound) or Stereo, and chooose bitrate also, 224 is good usually. Click Besweet tab, Select MP2 as output, now click 'wav to mp2' on right side, and ur audio conversion starts.
Now u have ur video and audio both at 23.976, load the mp2 file into windows media player to check the audio has been converted, it might be a second or two out compared to the video time (23.976FPS), dont worry about that if its just a few seconds, anymore than 10 seconds u might have a out-of-sync issue, but its usually ok if u change framerate wav > mp2, framerate change for AC3 is not recommended, it just doesnt work!
Now all u have to do is add ur 'VIDEO only' to ur favourite mpeg2 (DVD) encoder, and convert. After u convert to mpeg2, u must use a program called PULLDOWN to change the fps to 29.970 NTSC standard, but before using PULLDOWN, please rename the.mpv file created by ur DVD encoder to .mv2, so PULLDOWN recognises it!
Once this is done, use ur favourite DVD author prog, input ur video which was created by pulldown (movie_pd.avi) and ur 'AUDIO MP2' which u created with Besweet, and that will mux the 2 files together into the VOBS, BUPS & IFO's needed to create a standard DVD.
Once ur folder is created, use ur fav. dvd burning application to create a DVD Video, Nero is recommended.
Good Luck!
/DJ.
P.S. i learnt all this by searching the forums and creating my own system to convert, all information even regarding troubleshooting is available at this excellent site. -
i have like 3-4 sec difference between video and audio when i mux them toghether....what can i do?
Whenever I use this guide, I try using AC3Machine, and when I set it all up and hit "Give me AC3" it quickly shows a DOS window, which then disappears before I can see whats in the window.
It doesnt give me a file, so anyone any idea what Im doing wrong???
Oh yeah, and this is probably a spacker question, but when everyone says to rename the mpv file as a .m2v, how do you do this? I tried doing it by right clicking and selecting rename - but when I do this Pulldown still doesnt recognise it -
So exactly how many old threads are you going to dig upOriginally Posted by divisionbella
Convert AVI with H264 and AC3 to AVI with XVid and AC3
By ashwin.terminator in forum Video ConversionReplies: 4Last Post: 26th Jul 2009, 12:17 -
How to convert MKV to AVI AC3
By MLG in forum ffmpegX general discussionReplies: 3Last Post: 25th Jun 2009, 23:31 -
Convert divx avi with dts to ac3
By mk15 in forum AudioReplies: 3Last Post: 23rd Jun 2009, 04:46 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Trying to Convert avi. (Dvix) with AC3 audio file to DVD Format
By carlos305 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2007, 09:54
