Sorry about posting yet another sync issue, I'm sure the answer is somewhere in the 10,000 other open sync posts....and I am searching....
I am re-authoring a concert disk, that was once 2 disks that has been compressed into 1.
I had to reset the GOP time stamp using restream in order to get the video not to freeze in the middle. (the GOP timing was resetting at 0:00 where it was switching disks)
When I did an audio transcode on the original demuxed ac3 file, only the first half (which would have originally been disk 1) of the show has audio. Where it would have switched, the audio disappears.
So I used AC3fix which did come up with some errors that it fixed. When I performed the audio transcode on this, the entire show now has sound....but at the point where it changed from disk 1 to disk 2 (which is now all 1 file), the sound starts having a 2 second delay.
Should I just go in with an audio editor, and go to the point where the audio screws up and delete sections until they match up, or is there an easier way?
Results 1 to 1 of 1
"The sun won't melt our wings tonight..." -Bono
Final Cut Express audio sync
By EagleAye in forum MacReplies: 4Last Post: 24th Apr 2012, 18:39 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
Sync/align one short clip into one big clip
By diamondback in forum AudioReplies: 1Last Post: 2nd Nov 2011, 09:31 -
How do you insert an audio clip between audio clips in AVS Video Editor
By johnharlin in forum EditingReplies: 1Last Post: 19th Apr 2011, 01:17 -
How To Cut MKV Without Audio/Video Sync Problems
By Eva-Unit01 in forum Video ConversionReplies: 12Last Post: 2nd Mar 2011, 08:11
