I'm trying to establish the following simple point prior to buying a DMRE60 and would really appreciate any advice.
I want to transfer SVHS tapes to RAM. My simple but crucial editing system will comprise stopping the transfer every time I've gone too far, rewinding the disc a few seconds and continuing to record [thus erasing the last few seconds]. So I'm transferring most of the tape but using the RAM erase facility to cut out many small sections as I go along. This is exactly how I'd transfer tape to tape.
Will these edits be smooth and invisible? Will I end up with an unbroken sequence on disc with no signs at all that I have re-recorded at many points. If there is any sign of breaks on the final product that would be useless. I am also concerned that maybe there is some sign on the screen of chapter marks or whatever. I want to end up with one long sequence as far as the viewer is concerned.
Unfortunately no hard drive machine such as the DMRE100 is available here so I have to do the editing on the RAM disc. Using computers is not an option I can consider!! I don't have the skills or patience.
All advice will be welcome.
Have you tried asking this question in the DVD Recorder forum here:
http://www.avsforum.com
Might be better for answers...
IFOEDIT edit chapter points?
By wulf109 in forum DVD RippingReplies: 4Last Post: 29th Oct 2011, 20:42 -
PAL to NTSC Chapter Points
By sambat in forum Authoring (DVD)Replies: 7Last Post: 3rd May 2009, 08:52 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 10:39 -
new chapter points in PGCedit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2007, 13:51 -
Moving Chapter Points?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2007, 20:33
