Results 1 to 9 of 9
  1. Hi guys
    I have a big problem with tmpgenc. I have been using this program to convert files to dvd for ages now and feel i know how to use the program quite well, but this has stumped me totally.
    I have a 2 file movie, the movie is encoded in xvid, i exctract the audio from it (ac3) with virtual dub, but then when i go to load the avi (either cd 1 or 2) into tmpgenc the program comes up with a runtime error and crash's. It's not the first time this has happened and i think the other film i was trying to do was also ac3 audio and xvid.
    Does anyone know what i can do? i have already put the direct show to 1 in EV. and have the program running for windows xp.
    it's really baffling me, i've also converted the movie file from xvid into divx and it makes no difference.
    Any help would be appreciated guys
    thanks alot.
  2. Go into virtualDub, load your AVI.
    Go to File-> Save Striped AVI.
    Then try loading the new AVI in TMPGEnc.
    If that fails, try File-> Save Old Format AVI.
  3. Member Roderz's Avatar
    Jul 2003
    the armpit ofthe Midlands
    On my setup I had to put direct show to 4 for it to finally stop crashing!
  4. thanks for the suggestions am going to give them both a go in a minute. still any other ideas welcomed incase these don't work.
  5. Member marvel2020's Avatar
    Mar 2001
    Vorlon Home World
    Use VirtualDub to frameserve to TMPGEnc. Will take longer to encode but works
    I Have Always Been Here
    Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H
  6. ok i've got tmpgenc to accept the file without erroring, but now when i press start to encode it just doesn't respond and task manager says program not responding.
    This is startin to really get on my tits now lol.
  7. Member Roderz's Avatar
    Jul 2003
    What EV settings have you got - mine are below work with both Xvid and Divx for me.
    Also TMPGEnc don't take ac3 audio files (I think)
    Save audio as wav in Vdub then run it through AC3fix GUI (if u want 2 keep ac3 audio) or convert to wav with Ciler's Ac3Tool,
    Use TMPGEnc - just do ES (video only) then feed both files to your authoring prog (I use TMPGEnc DVD Author)
  8. try to put the "AVI2(OpenDML) File Reader" on priority 5.
    you might get an error when the encoding is finished,
    just ignore it.
    HELL AINT A BAD PLACE TO BE
  9. i've sussed it it's all working now, now i feel i can convert nearly anything, well that is apart from my huge pile of paper work into a nice pile of icecream, ALACAZAM, damn nope didn't work
