I am trying to change the Microsoft codec (avi decompressor) to the MainConcept codec (MainConcept DV video decoder) from an avs script. But all I get is this error,Someone solve this for meThe filter cannot agree on a connection. Verify type compatibility of input pin and output pin. No combination of intermediate filters could be found to make this connection. (Return code: 0x80040217)
Thanx, AK
it doesnt mater which dv codec is used for decompression -- it only maters which is used for compression ..
But why did you suggest in this from, https://www.videohelp.com/forum/viewtopic.php?t=184231 this
Because MCE is running about the same speed as TMPGenc. I just want to know why is that.its switching between Microsoft and Mc dv codec ..
use graphedit and see which one is being used ...
you can set priorities in mc options ... try to turn off one or the other avi readers .. -
"try to turn off one or the other avi readers"
IN the MC options --"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Changing subtitle error!!!
By Aandis in forum SubtitleReplies: 11Last Post: 28th Jan 2012, 13:31 -
hard copy subs without changing codec fast
By Ceesar in forum SubtitleReplies: 15Last Post: 21st Oct 2010, 11:38 -
Dvdstyler error changing background image
By EAGLEEYE in forum Authoring (DVD)Replies: 0Last Post: 11th Jun 2010, 23:52 -
DV-avi codec error????
By crb119 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 12th Jun 2009, 07:49 -
error installing K-lite codec pack
By Shotobits in forum Newbie / General discussionsReplies: 4Last Post: 22nd Mar 2008, 03:38
