  1. Hi
    Is there a way to see the drop frame rate during capture with ulead visual studio 7?
    Thx
  2. Originally Posted by rubber_duck
    Hi
    Thx
    Not according to the FAQ:
    http://www.ulead.com/tech/vs/vs70faq_01.htm#7
    "Q: What happened to the drop-frame counter?"
    "A: The drop-frame counter has been removed to conserve space for other topics."
    Jerry Jones
    http://www.jonesgroup.net
  3. Thank you specialist ,
    I suppose there is no way arround.
  4. I got the following tip from an acquaintance with Ulead:
    1. Locate HerCap.ini file in the C:\Documents and Settings\All
    Users\Application Data\Ulead Systems\Ulead VideoStudio\7.0;
    2. Open HerCap.ini file and add "ShowFrameNumber=1" below [CAPTURE_SETTING]
    section.
    As follows:
    [CAPTURE_SETTING]
    ShowFrameNumber = 1
    3. Close and Save the ini file;
    4. Launch VideoStudio 7 and go to Capture stage;
    5. You will see the drop frame counter.
    Note: 1024x768 display area will make the drop-frame counter not show very well on the Option Panel; however, you still can see it.
    The drop-frame counter will be showed completely when the display area is changed to 1280x1024.
    Hope this helps,
    Jerry Jones
