Hi i've been encoding avi's to dvd for some time now, but recently i downloaded a avi from the internet. I want it at its highest possible quality when i put it onto DVD. I use TMPGEnc to do this. But recently i heard that if a avi has a certain 'average video bitrate' for example 6000 kbits/sec there is no point in encoding it at 8000kbits/sec as the quality won't get any better once it's past the setting of 6000 kbits/sec. My question is though, how do I find the 'average video bitrate' of the avi?
thanks, any help would be brilliant.![]()
Tools
Just a thought.. Isn't that possible to check with Explorer? Just check the Properties of a DivXfile and choose Summarytab then Datavelocity (don't know if the english word is velocity). It can say 210.000 kB/sec, that would be the same as the bitrate of 2100 kpbs?
I don't know... -
thanks for your helpful reply's, i'm working with that software u showed me. Thanks again.
You could also divide the file size in bits by the playing time in seconds.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Finding out the peak bitrate of a DivX file
By Anakin in forum Video ConversionReplies: 2Last Post: 8th Oct 2011, 16:25 -
hanbrake average bitrate
By scarlac in forum Video ConversionReplies: 4Last Post: 12th May 2010, 14:35 -
Trouble Finding Bitrate for DivX Xvid for CD-r
By 4194 in forum DVD RippingReplies: 9Last Post: 24th Aug 2007, 11:41 -
VBR (2 pass, average bitrate) Encoding for DVD-9
By jcm0320 in forum Video ConversionReplies: 3Last Post: 15th Aug 2007, 10:44
