OK, I'm trying to get my Canon ZR70MC to pass-though an A/V signal to my PC. As far as I know I have it set up correctly, but I'm having a couple problems.
While I was able to use VirtualDub for captures from my ATI AIW< when I try using VirtualDub for this it chokes saying there is no driver.
If I use the native Windows support (like MovieMaker) I have no problem seeing the image, but there is no sound. I've gone though the audio settings to no avail.
I have WindowsXP and have the camcorder hooked up via FireWire though my Audigy FireWire port. (it's the high speed model port) The camera is set to do A-D and use video input. The video signal comes though no problem, but I can't get any sound out of it. The cable connecting the external sound is a combo cable which includes the video.
The drivers seem installed correctly as the system recognises the device when connected. Just no sound.
Any thoughts?
Regards,
Savant
Sorry if I misunderstand but...
...are you meaning you can't hear audio as you capture, or after you capture and then play it back.
If it's during capture then it's not unusual, I can't hear audio when I transfer my DV fotage via firewire, but it's fine during playback.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
I was talking about before/during capture. When I setup to capture I see the video but hear no sound. Normally I am accustomed to a capture playing audio as it comes in. (ala VirtualDub) I never bothered to try a capture since I couldn't get any audio. I'll try some test caps and see how it goes, thanks.
What are you using to capture your DV footage on your PC BTW?
Regards,
Savant
Canon DC230 New Ticking Sound On Playback
By cool4cats in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 7th Jan 2012, 07:23 -
Canon HV40 analog/digital pass through?
By stantheman1976 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 30th Jun 2011, 06:23 -
Sony Hi8 (PAL) pass-through to Canon (NTSC) - will this work?
By frappefan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Dec 2010, 13:18 -
Canon Rebel xti + Canon HV30 vs. Canon Rebel T2i
By assman24 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 17th Jun 2010, 11:47 -
Several questions about "pass through" and Sony/Canon camcorders
By tadd5181 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 9th May 2010, 12:42
