  1. Hey folks. I've got 1 .vob and 1 .ac3, thats it. How can I turn those two files into a dvd? :P
    (Really all I need to know how to do is to make a .IFO from those two files then I can burn it but I don't know how to make an .IFO)
    Thanks.
  2. The easist way would be to run them through an authoring proggie.
  3. Read some guides.
    Mar 2003
    Uranus
    Doesn't the VOB have audio already ?
  5. FOO yah, normally, but I extracted it out and edited the curse words out for my history class, now I have to put the ac3 back to the vob so I can burn it. Any ideas?
  6. Demultiplex the Vob file(s)...
    You will then have an MPEG2 file and an AC3 File.
    Delete the AC3 File.
    Then Multiplex the MPEG2 file with the new AC3 file.
    I think IFOEdit can do (de)multiplexing.
  7. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Well I never tried this myself as I have never had the need to do so but I think that Vobrator can extract the video from the VOB (M2V I'm guessing) and then you can import the M2V and your AC-3 into an authoring program.
    - John "FulciLives" Coleman
