  1. Hi,
    I have a LITEON DVD-ROM LTD163 that came with my Dell Dimension 4550 (XP Home). I have read that the LTD163 is one of the best/fastest drives to rip movies. I have updated the firmware (to GDHJ) and uninstalled then reinstalled IDE controllers and enabled DMA on all devices, as recommended on all the pages I have read, but both DVD Decrypter (3.1.6 and 3.1.7) and SmartRipper (2.41) continue to rip with a max speed of 2x-2.5x, taking an hour or sometimes more to rip a movie... I am trying to find out what I need to do in order to be able to rip a movie in 10-15 minutes, as many have been able to do...
    Any suggestions?
    Thanks for your time...
  2. Member scottb721's Avatar
    Oct 2002
    Australia
    You've probably done as much as what anyone here could of advised, unfortunately.
    Good luck.
  3. I have read that there is a deliberate speed limit on ripping from DVD recorders, posted with the advice to try using a DVD read only unit. I have an internal NEC1300 burner and an older generic DVD player in an external case connected by USB, rated slower than the NEC. Ripping from this unit is consistently 2-3 times faster than the recorder, tho.
    fREBieware- you get what you pay for.
  4. I have a 166s which is basiccaly the same dvd player and mine can rip any where from 7x to 16x depends on the dvd i'm ripping. Your setup sounds right i have know idea what the problem could be. I use dvd decrypter 3.1.6.0 Win.98se.
    Apr 2003
    Largo, FL
    I'm using a LITEON DVD-ROM LTD163 and it rips from 4-14X on most movies, so the problem is probably not the drive.
    I don't know what else you could do. Have you re-checked that DMA stayed enabled after you enabled it? I know that occasionally mine resets itself to PIO only (haven't figured out why yet) and I have to reset it.
