  1. Greg C
    Guest
    I found a misspelling and some layout issues with a DVD menu that I recently created. The menu looks great on WinDVD (other than the misspelling), but the edges are off the screen when played on a DVD player. I just need to move some of my buttons away from the edges of the background so that they'll show up on my TV. Is there a quick and easy way to edit the menu?
    All I have is the DVD+R. My source files were deleted.
    I'm trying fix this problem without having to rip the mpg's from the DVD and starting over.
  2. Tip1: if you use DVD Menu Studio then you can see markings of what will be shown on tv.
    Tip2: don't ever delete your source before you checked if your dvd's are working.
    Tip3: buy a dvd+rw cause you are going to need it.
    Greatings,
    Yf
