I have searched the the forums for an answer but couldn't find exactly what I am looking for.
Someone please tell me which combination of source and output aspect ratio I should use if I just want to create a VCD exactly as the DVD was created. I'm not trying to crop, resize, add black borders, etc.
Here's a more detailed description of what I've done:
I am trying to encode a widescreen movie into VCD and watch it on the TV. It came out stretched vertically, so basically people looked taller. The tmpgenc source setting was NTSC 4:3 and I tried 2 setting for output: fullscreen and fullscreen keep aspect ratio. You might wonder why I used 4:3 source setting for a widescreen movie. It's because I read somewhere on this forum that if the source is meant to be played on a 4:3 (ie, most commercial DVDs), then that's the setting to use regardless of what aspect ratio the movie is presented. Maybe this is my problem?
I then did several tests by encoding using both NTSC 4:3 and 16:9 as the source ratio, and for output, I used centered, centered (keep aspect ratio), full screen, fs (keep AR), fs (keep AR2). I was trying to predict which combinations would look okay which would look weird, and I ended up thoroughly confused. Selecting the 4:3 and 16:9 didn't seem to matter.
Andy
16:9 525 lines
Fullscreen keep aspect ratioEjoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
you should keep the source at 16:9 not 4:3 because it will stretch. Now your problem might be your dvd player because some will recognize widescreen and if you have 4:3 pan and scan it will stretch the picture to utilize your tv screen. Now to cure it, set your dvd player correctly or encode at 16:9 and set tmpgenc to full screen no margins. This will fit your tv better but it will crop each side of the picture. more info at htt://entiendo.gotnet.net
No aspect ratio 5/4 in Tmpgenc Xpress
By sychern in forum Video ConversionReplies: 1Last Post: 29th Sep 2008, 03:06 -
Tmpgenc xpress Image Resolution & aspect ratio
By sychern in forum Video ConversionReplies: 5Last Post: 24th Aug 2008, 08:25 -
16.9 Aspect Ratio with TMPGEnc dvd author 1.6
By GJF in forum Authoring (DVD)Replies: 22Last Post: 24th Jun 2008, 03:57 -
Tmpgenc Express: Aspect ratio problem
By shashidar in forum Video ConversionReplies: 1Last Post: 11th Mar 2008, 18:59 -
Aspect Ratio's
By AndySpring in forum Newbie / General discussionsReplies: 7Last Post: 23rd May 2007, 12:55
