Hi there this is an encoding timescale question. How long does it take I’m using Panasonic mpeg 2.5 encoder and it take rather a long time 3 hour for 50 min.
I know there are other encoders out there but are they any quicker and if so what are they ray
you should be more specific, ie what youre computer specs are and the length of your movie etc.. and if you think 3 hours is a long time, your in for a shock
Amd 1300 256ram mx2 msi mboard via chipset 20gig 7200 hd win me, running latest drivers as of this month.
Ok I’m trying to encode a 350mb avi file with the Panasonic 2.5 mpeg 1 encoder, it takes on average about 3h.30min to encode 50 min of video on to mpeg video audio stream and if this is normal then well that fine but if not then what’s a better programme to use. Thanks for the input, also is there any really good guides or links out there faq that sort of thing thank a lot ray
If you use avi2vcd audio decompresser and run TMPEnc after, you will be eable to encode an 800 mg avi file in 4-5 hours.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 10:13 -
Your Best Video Encoder/Re-encoder???
By iqbal88 in forum DVD RippingReplies: 2Last Post: 15th Aug 2011, 09:09 -
Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
By TheViking in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 02:41 -
how long
By Tobias0815 in forum FeedbackReplies: 3Last Post: 1st Jul 2008, 20:08
