I've got a Cyber Home dvd player compatible.
I record my dvd+r with Ulead Workshop with menu and music and blah blah
Of course the menu is perfect but when I try to play the content (movies, episodes, whatever) it appears for 1 sec full screen and then all compact in half a screen.
I get my mpegs via Kazaa or Suprnova
I dont edit before loading them in Ulead Workshop cause I dont know how to do it and which are the right features?
Anyway the properties of one of the files are
File Format MPEG-1(PAL VCD)
VIDEO
Attributes 24 Bits, 352 x 288
Frame Rate 25.000 Frame/Sec
Data Rate 1150 kbps
AUDIO
Layer 2
Bit rate 224 kbps
Attributes 44100H Hz, 16 bit, Stereo
Is that ok? (I really dont think so)
And if I should change the properties, how can I?
Thanks a lot!
Results 1 to 1 of 1
Split screen, keep aspect ratio and use half of 2 different videos ?
By boulder in forum EditingReplies: 10Last Post: 10th Nov 2009, 12:30 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 09:35 -
MS Word XP PgDn advances the text half-screen only
By walter4h in forum ComputerReplies: 2Last Post: 10th Oct 2007, 22:07 -
MPC DVD playback - I can only see half of the screen
By giaitchison in forum Newbie / General discussionsReplies: 3Last Post: 8th Sep 2007, 03:02 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 12:16
