gOOD DAY. jUST WANTED TO KNOW :
If I'll be able to capture from a sony pal camcorder to my pc, will I be able to view or play captured file(pal format) in my computer? if so, what tool should I use to view it on my PC?
tnx
All modern computer monitors are multi-system so there is no problem with either PAL or NTSC.Originally Posted by eckoviscon
The problem is mostly with TELEVISIONS which tend to be either NTSC only or PAL only although the Europeans keep saying that most European TELEVISIONS are multi-format these days.
I live in the USA and a multi-system TV is rather rare here. Almost all of our TV models are NTSC only.
- John "FulciLives" Coleman
P.S.
Is the SONY PAL camcorder a digital model (either Digital8 or DV) or is it analog such as 8mm or Hi8 etc?
It makes a difference as to how you transfer or capture."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
NTSC or PAL is only relevant if you want to output your video on a TV screen not on a computer monitor !!!!.
The best player for your captured program will depend on your capture format. As a strating point, you can always try windows media player which will play most format.
And yes, most TVs in Europe are multisystem PAL/NTSC, PAL/NTSC/SECAM, unlike here in the US. -
Thank you very much guys for the help. I think its an analog camcorder. I'll be using my WINFAST2000XP TV TUNER CARD and ULEAD VIDEO 7 for capturing. Is it just fine?
tnx again and more power.
God Bless -
Should work as long as your software supports PALOriginally Posted by eckoviscon
Also know that there are many different forms of PAL so be sure to find out which one is the correct one.
Tnx again sir.
If I successfully capture said footage and able to view it on my pc my next inquiry is :
I have a graphics card that supports tv out. Will I be able to view(captured footage still on pal format) it on an ntsc television connected to my grahics card's tv out.
tnx
Issues authoring Blu-ray disc from captured footage
By SportsorDeath in forum Newbie / General discussionsReplies: 11Last Post: 21st Feb 2012, 11:10 -
captured footage, now notice a line throughout frame
By Ray S in forum Capturing and VCRReplies: 1Last Post: 15th Sep 2011, 11:38 -
VHS player connected to PC - all captured footage out of sync!
By kingmustard123 in forum Video Streaming DownloadingReplies: 2Last Post: 30th Jul 2011, 16:23 -
Horizontal Streaks on Captured Footage....
By D.V. Dee in forum Capturing and VCRReplies: 12Last Post: 19th Jun 2008, 11:40 -
Loading footage captured on DV tape, shot with HDV cam??
By Anthalloran in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 8th May 2008, 11:04
