  1. ok when doing a copy of a copy or iso in dvd decryptor i always browse to the iso image but made a mistake and browsed to the mds file today and it worked the same
    which brings the question which one is best to browse to
    i have always not used the mds but maybe im wrong
    anyone got an opinion
    what i mean is when you read iso it makes 2 files one mds and the other iso
    so when you go write iso do you browse to the iso or mds file
  2. 32 views someone must use dvd decryptor
  3. Banned
    Dec 2002
    either one does the exact same thing...
    have you used clone cd? it makes a .ccd and .iso file too
  4. use clone all the time but not for iso
    I have always used the iso file but thought using the mds might be wrong although they both work..
    thanks for reply
