  1. Hello
    I tring to use DVDShrink for a movie. After that i have riped it to my hdd i load it in shrink as always. But the swedish subs isnt there. The swedish sub is nr 11 and DVDShrink just shows 10. I have tried Beta 3 and that didnt worked. Well it did find the sub but the movie didnt work wene selecting play movie. I want to use 2.3. Please help me.
    I have used dvdshrink on 10-15 movies and never had this problem.
    THX
    USiT
  2. You should just buy the movie, I can guarantee it will work perfectly for you then!
  3. why should i buy the movie when i already have it?
    I wanna do a backup so i dont have to use the org all the time.
  4. USiT, whether you use v2.3 or v3.0 beta 5 (recommended), there is an option in the "Edit" >> "Preferences" menu:
    "Only show subpicture streams of significant size" (or similar).
    Try unchecking it.
    ddlooping
    For DVD Shrink guides & goodies: DVDShrink.info
    My "other" site: Teaching-Tools
  5. Ahh thx alot that did it. I hade also have to check split the files in beta 3.
    Thx Thx
  6. Some movies and be tricky some time's subtitle's are renamed so you pick the wrong one's and have a bad DVD. Use PowerDVD to check if the subtitle's are in order as they are named. If you still have a problem.. Back up the hole DVD. I use DVD2ONE has it keep's Closed Caption subtitle's also. Also CloneDVD will copy Copy caption subtitle's.
  7. Member wulf109's Avatar
    Jul 2002
    In the Preferences box uncheck the option that says display substreams of significant size only. Small streams of a few MB's won't show if this box is checked.
  8. Originally Posted by USiT
    Thx Thx
    You're welcome. Glad to be of help.
    ddlooping
