Hey...
Yesterday i installed a DVD-RW drive (LiteOn LDW-411S) and since then, my DVD-ROM drive get's recognised as a CD-ROM drive by WinXP Pro.
It indeed does not play DVD's anymore, it just keeps spinning, and windows locks up.
Any ideas on this? thanks!
Most likely you have both drives installed as a primary or slave so you should check the drive jumpers to be sure one is set as a primary the other a slave.
Originally Posted by Bob W
And as i said, the drive still works, it just isn't able to read DVD's anymore. It does still play Audio CD's and CD-ROM's.
Floppy Drive Not Recognised
By spliffy in forum ComputerReplies: 38Last Post: 26th May 2010, 02:45 -
Replace dvd drive with dvd-rom drive.
By jtrapat1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Dec 2008, 10:33 -
Help on Choosing a DVD-Rom Drive
By scustalow in forum DVD RippingReplies: 1Last Post: 13th Jun 2007, 11:04 -
My DVD drive wont record Deul Layer anymore.
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 11th Jun 2007, 15:07 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 07:55
