i have used pinnacle instant copy v8 a few weeks ago and had no problems whatsoever. but recently i had to install a fresh copy of windows xp pro due to some other issues. and when i installed my copy of instantcopy v8 i cant seem to get it to work right. when its analyzing the video sets i dont see the images being displayed on the pinnacle window, which is pretty strange sense i could see the images when i had it on my old windows xp. and i selected the option so that i could see the analyzing images being displayed and that still didnt work. and i have another problem and that is, that it completely stops analyzing all of a sudden. wich is strange again sense i have never had any of these problems with it when it was installed on my old windows xp before. then i thought it must be something wrong with the dvd, so i ripped two other ones and they both gave me the same problems. so i finally uninstalled it and then i re-installed it and had the same problems. but i got these weird messages after i had to restart my pc. it said something about a driver prlblem or something along those lines. so i want to know how to fix it if there is a wayany help is appreciated
Results 1 to 20 of 20
can you uninstall it again and then do a system restore to before you installed it?
what did you click when it asked about the driver?
you may have to unistall it then manually remove the IC8 references from the registry and try to do a fresh install
it sometimes does get messy installing IC but you can normally pick up the pieces
i realized now that the message only comes on if i install the virtual drive with instant copy as well. so now i only chose to install the instant copy and i didnt receive that driver message again. but i still cant see the images being displayed in the windows and it stills stops completely when its ananlyzing the video sets. so how do manually remove the IC8 references from the registry so that i can do a fresh install? thanx in advance.
HKEY_CURRENT_USER\Software\VOB\CD Wizard\7.5 is the IC8 reg entry
it may also be in the HKEY_LOCAL_MACHINE\SOFTWARE\VOB\7.5
I would just uninstall IC8 and delete the complete VOB folders in the registry in both then reinstall IC8 and not bother with the virtual drive. There are also Pinnacle folders in the Softawre folders and again I used to just blitz these also
I just can't remember exactly how to do it now though but maybe some else can knows better
also get hold of ICHSE 1.41 HERE if you haven't already -
well i just deleted the software but i dont know if it deleted the references from the registry. i went to the programs folder i didnt see no pinnacle folder and no vob folders and other folders in there, so im guessing its all been erased or has it?
the VOB folders I am talking about are the ones in the registry
do you know how to open regedit? -
sorry mackemx but i cant even find where the registry is located, that alone the vob folder
. and i dont think how to open the regedit either.
no probsOriginally Posted by supersam
just click START then RUN and type regedit in the small run window that pops up and this will open regedit
then you can browse to the folders as you will see them listed on the left but you must be very careful in what you are doing. Maybe it's best you read up on it first unless you feel confident enough to do it now
all you do is expand the folders and then you will see the VOB folders. Rght click the VOB folder and delete it and od it for both. Just close regedit as it will instantly update the registry anyway and that's it
it's simple but may be a bit tricky to understand at first so again be careful
ok..pretty straight forward stuff
but do i delet just the subfolder(7.5 folder) or the entire vob folder?
you can just delete the complete VOB folder as long as you have all your IC discs etc as a new one will be created anyway when you install again
i delete from both the local machine and from the current user right? just wanna make sure if i only have to do it to the current usre only
just blitz the lot
even blitz the Pinnacle folders which are in the Software folders. That's if you have only ever installed IC of course as you may have other Pinnacle products that would be affected if you did delete the Pinnacle folder
all these folders you are deleting will all be replaced anyway
but once you have deleted them all, make a restore point so you can always go back if something goes wrong during install -
ok i have deleted all the folders that correspond to IC8 and have made the system restore point. but i cant download the file u told me to get. it said that im not a registered user.
you dont need ICHSE at the minute anyway but I think mrbass has it on his site somewhereOriginally Posted by supersam
http://www.mrbass.org/instantcopy/ -
hmm..its still doing the same thing. oh well i'll just call it a lose and move on then
but thanx for ur help mackemx
so do u think it has something to do with the reg. or could it be something else?
If you can not see the "play" button and the "stop" button in the preview window of IC, the problem is from DPI setting in Windows is too large. Do as follow:
Right click on any blank area of the screen. The Display Properties window would pop up.
Click settings tab > Advanced > DPI Settings
Set it to 'Normal Size". Exit and while still in Display Properties, click on the "Appearance" tab. Set the Font Size to "Normal".
Exit completely and re-start Windows. There's a very good chance that you'd be able to preview your tiltles in IC now. -
thanx for the help falberni but my dpi is set to nornal already and so is my font. my dpi is set to 96 which is nornal.
hey mackemx i just realized something on my control panel as i was deleting IC8. the program was only about 19mbs and i know that that's not right at all. the overall programs size is around 60mbs or so give or take or something along those lines. so i was wondering if that is the correct size or is the installation process not installing everything that is needed. thanx in advance!!!
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
