    Oct 2002
    dallas tx
    why is it that when i use dvd2one i have the file set to 4472 but when it's finished it gives me a file with the size of 4.50 gb
  2. make sure it is the newest version.
  3. You probably chose VBR, and it's not so good with VBR. Try using CBR, or DVDShrink.
  4. DVD2one V1.3.0
    Here's a new version of DVD2one with the following new features:
    Added a powerful new copy mode: the join mode. You can read all about it on this page.
    Added default audio and subtitle selection for movie-only and join mode. Just doubleclick on the row to select that language as default.
    Added a special feature for join mode to navigate through the different titlesets. Just in case your dvd player does not feature a disk navigator itself.
    Fixed a small problem in the compression ratio calculation, which could affect the destination size estimation of the variable ratio mode.
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
