I just discovered the strangest thing! Since I’m having troubles with frame drops I tested my HD with the EZDV Test utility. I have four different partitions on my drive. I tested each of the partitions, and then noticed that one of them had a significantly higher read/write rate. What differed was that this partition was compressed. This puzzled me, because to my knowledge compression takes time! Just to make sure, I compressed another partition, and guess what! The read/write increased by a third! Then I changed the partition back to a non-compressed partition and the rates went back to the original rates. Is this possible? What is going on?
My system:
PIII 1Ghz
HD Maxtor 52049H3 (20Gb ATA-100)
256Mb RAM
Win2k on NTFS
Before compression:
Read 27MB/s
Write 26MB/s
After compression:
Read 86MB/s
Write 37MB/s
What is going on?
Memory is much quicker than hard, so data is compressed in memory and then be writen to disk. -
Previous answer not entirely correct. Speed difference is because you are spending less time writing data. Fast processors can compress the data to approx 50% in less than half the time it would take to write the original file, so you get faster performance. This performance gain is highly variable depending on file type, do same test with a group of EXE files and gain will be much less.
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 08:57 -
Read/Write at the same time
By mis3 in forum DVD & Blu-ray WritersReplies: 10Last Post: 22nd Oct 2009, 11:29 -
Attempted to read or write protected memory.
By big40dog in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 17th Jan 2009, 07:51 -
DVD burner read/write speeds
By ecc in forum Authoring (DVD)Replies: 9Last Post: 13th Apr 2008, 06:49 -
Why are High Speep Internet Rates So Much Higher In Japan than US?
By videobread in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2007, 22:51
