I'm still working with the trial version of DVDLab and there's several things I can't figure out (seems like a good program, but hard to find complete guides/instructions).
Right now I'm trying to figure out how to delete a movie. I put 2 movies in a project, then decided to just use the 2nd one. I deleted the video and audio (and connections) from the first one. When I tried to compile the disk I got a message saying there was no video/audio in movie 1 and I had to delete it before compiling, but I can't figure out how to delete it.
Same for menus- I've added too many menus, but can't delete any of them.
Thank you. I would have never thought of that- I've been right clicking on everything and looking at every option in the sub-menu.
I wouldn't waste your time with DVD Lab, it makes discs that don't comply with the DVD Spec and can cause major playback problems, and if you ever want to have your discs duplicated or replicated you are pretty much screwed because nobody will accept them. Better off buying a REAL dvd authoring program.
If you can find it on e-bay etc, then DVD Maestro is very good, but sadly Spruce no longer supply it.
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
DVDLab Pro Menu Structure Questions
By raouliii in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2007, 22:32 -
Is there any other software like dvdlab?
By anfield7 in forum Newbie / General discussionsReplies: 7Last Post: 1st Oct 2007, 05:55 -
DVDLab - 2 questions (design & connections)
By LynnL in forum Authoring (DVD)Replies: 3Last Post: 23rd May 2007, 09:25
