I'm trying to install new drivers for my AVerDVD EZMaker capture card.
I've downloaded the file for my capture card (EZMakerDriver.Zip) from Aver.com and have unzipped, but there are just files that have been unzipped with no setup file to install the items.
The files are:
bt848 (System fie), bt878 (Setup Information), btxbar (Setup Information), btxbar (System file), cat878 (Security Catalog), catxbar (Security Catalog).
Any help appreciated.
Bruce
right click my computer
goto properties
then device manager and hardware
find the card in the list and right click it
click properties and find update drivers
then browse to the folder where the files are located.
hope that helps
DirectShow and Drivers--multiple instances of the same capture card
By Austin Covello in forum Newbie / General discussionsReplies: 0Last Post: 7th Feb 2011, 10:43 -
Updated Drivers Software
By mn072065 in forum ComputerReplies: 7Last Post: 9th Mar 2009, 05:23 -
Unable to transfer some VHS to DVD using AverDVD EzMaker PCI Card
By fromvn in forum Newbie / General discussionsReplies: 4Last Post: 26th Oct 2008, 11:38 -
TV Tuner / Capture Card - WinDVR 3 no Audio after Windows Vista install
By buzzsaw in forum Capturing and VCRReplies: 20Last Post: 12th Oct 2008, 15:06 -
Help with drivers? Initialization in my Capture Card!1
By hkseo100 in forum Capturing and VCRReplies: 0Last Post: 7th May 2008, 19:41
