can someone tell me where i can find thses dll files
Cinmhook.dll, Cinmst32.dll & Dvdpld32.dll i looked every where on the web
Results 1 to 17 of 17
they are on your maestro installation cd in the setup folder for cinemaster 95 or you can install cinemaster2000
Do you know were to find and download cinemaster 2000 ?
Or, could you send me these dll files?
I didn't find it im my DVD Maestro cd... -
I would suggest you look closer on your cd, unless you don't in fact have one, in which case, don't ask for help with rip offs here.
I'm asking only for the dll files if you can see that.
Nothing more.
Anything more than that is only your sick imagination.
These are the rules here:
Do NOT give warez.
Do NOT link to warez .
Do NOT ask for warez.
Do NOT provide information how to obtain warez.
Do NOT advocate warez.
Do you know what warez means
Please, read The Forum rules / Acceptable Use Policy
I'd like to buy Cinemaster (it didn't come with my disks
). Do you know how or where
Do us a favor, ok? :
If you can't help, get out of the way, at least.
This forum is just for people who needs help or wants to help. -
Asking for Dll's you don't have a right to is still asking for warez. As to wether or not you have a right to those Dll's, the Jury is still out on that one.Originally Posted by cunhamr
Surley you can see that a new members 1st post asking to be provided with dll's from commercial programs is rather suspicious. -
Ops...Sorry... You are mistaken.
Neither Cinemaster 2000 or Maestro are seld anymore...
They lost the main characteristics of a comercial product.
I have DVD Maestro (legal !!!) software but the DVD player that came with it is not Cinemaster 2000 and doesn't work in win2000.
As I said before, I'd like to buy Cinemaster.
And the suspicion is only in your mind.
Regards,
Marco -
Curious you need a few DLL's and not the whole installation?
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
If you do a google search for Cinemaster, as I did, there are several web sites that say you can get preview mode to work in Maestro with these dll's. A full installation of Cinemaster, any version, is not needed.Originally Posted by Gazorgan
In your original message it was as above, WITH the wink included. Now to me that indicates you don't have the original CD.Originally Posted by cunhamr
For some unknown reason you found it nescassary to edit out the wink in that message before writing again............ I wonder why? -
Mistaken... the wink was
The reason is:
I was very, very, very afraid of a bad interpretation by a child.
It's enough. I stop here.
Let's talk about the subject...
I'll ask again:
Does anybody know where to find Cinemaster 2000?
Or some plugin for Maestro in order to get real time preview? -
its on the installation cd ---
../DVDMaestro Installer/Drivers/QI NT4/
install these drivers cinemaster 1.2 drivers (for nt4) - works on 2k and xp (not the program but the dll's) ...
cinemaster 95 was on the update cd from spruce
cinemaster 2000 works on xp (not from spruce)
../DVDMaestro Installer/Drivers/QI DVD Player/ is also there but ive never had to install it (but i use cinem2000) i think...
Cinmhook.dll is the same version.
Cinmst32.dll and dvdpld32.dll is different version w/ 1.2 - 95 - 2000 versions
2.0.16.1254 is the latest - any version should work most likely .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
also -- tthe rights to both maestro and cinemaster are still retained and valid -- they didnt "lose the aspects of a commercial program"
maestro is owned by apple ...
cinemaster is owned by sonic (and still sold) ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
So... I asked Apple. They bought the technology, not the product.also -- tthe rights to both maestro and cinemaster are still retained and valid -- they didnt "lose the aspects of a commercial program"
They don't have it to sell.
In the Sonic site there is no Cinemaster 2000, only 99.
Cinemaster 95 is not working in win 2000 even with those dll files that I've already found in my disks (thank you BJ_M)
I'd like to know if the 99 version would work but the technical support is unavailable.
In the spruce users forum I found something about DVD Fire...
I'm gonna try and let you know.
They have the appropriate answers...Not smart to agitate a moderator. -
99 doesnt work ... but the elsa version found on elsa video driver cd's works ... though its called something else ...
95 , 1.2 , 1.02 , and 2000 (and elsa) are the working versions (there are some other OEM versions that were out there also) ... put the dll's in your maestro directory and system32 directory ...
the dvd/cd writer engine in maestro is by gear .. and also can be updated to a point (if you use the maestro writer)... the spruce mx3000 encoding card is still one of the best ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Need aacenc32.dll & aac.dll for be light
By tofuguy in forum AudioReplies: 5Last Post: 30th Oct 2011, 19:58 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 13:27 -
MeGui -> Unable to locate libsndfile-1.dll and FFTW3.DLL
By whatever911 in forum Video ConversionReplies: 0Last Post: 21st Feb 2009, 15:34 -
Nero 7 installed but no aac.dll or aacenc32.dll?
By AndyD in forum AudioReplies: 5Last Post: 13th Jan 2008, 19:28 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
