Is there anybody out there who owns the same model? Did somebody try cdrdao with this model?
Yes, I have this drive
Both Nero and CDRDAO work fine on it.
Funnily enough, Adaptec Ez CD Creator (the software shipped with the drive) buffer under-runs about 50% of the time.
Crappy bit of software anyway. -
Dave
Thanks. What OS are you using? I'm using WinME but can't make cedrdao to work with my drive. I have installed the new ASPI. But it didn't help. What driver do you use with cdrdao? generic-mmc? -
Hmmmm. OS should not matter should it. i mean i couldnt get CDR-DAO to work on my drive either, but that was because i could figure out the command line client and i deleted it instead of bothering to learn. Just a suggestion, maybe Adaptec buffer underruns because you dont have enough ram? i bought an extra 128 and now Buffer Underruns are a thing of the past. anyway, Dave, you are right, the new adaptec software is crappy. I have Easy CD Creator version 3, and it is extremely useful. Much better than 4 or 5 by a long shot, so if you want it, i can get it to you, its about 30 megs in size i think.
Yeshi, don't give up on CDRDAO -- it is definitely one of the better burners out (and free). There is a Win32 GUI available called "XDuplicator" that removes the hassle of learning the command line switches.
Regards.
Michael Tam
w: Morsels of Evidence
