hello
I gave ifoedit a m2v and a ac3
and it gave me 4 VOBs.
Can I make it to generate "1" VOB or 1 "mpg2"(I prefer mpg2)
Or...
Does TMPGEnc DVD Author achieve my goal?
(I have not used TMPGEnc DVD Author yet)
thanks
Tmp can be feed with m2v and ac3. But it makes a "dvd" so I don't think you get just one vob. you get all the vob's that are required. How many seem to depend on the size of your dvd. I haven't seen a vob bigger then 1 GB, they seem to get sorted or divided into 1 GB vob's.
Sound turned to white noise when using TMPGEnc Xpress & DVD Author
By Hal05154 in forum Authoring (DVD)Replies: 4Last Post: 15th Jan 2009, 22:03 -
Help.... Conversion & Author Problem with TMPGENC Xpress V.4.4.1.237
By milindb1 in forum Video ConversionReplies: 19Last Post: 22nd Sep 2008, 02:40 -
TMPGEnc DVD Author 3 & Overscan
By heyjjjaded in forum Authoring (DVD)Replies: 4Last Post: 11th Aug 2008, 01:24 -
TMPGEnc DVD Author & Dolby 5.1 Digital Sound - Can it be Done??????
By Sparehead01 in forum EditingReplies: 2Last Post: 28th Dec 2007, 14:53 -
IFOEdit - Author DVD - Chaps Failed
By mattstan in forum Authoring (DVD)Replies: 2Last Post: 6th Nov 2007, 06:44
