Hey,
I was wondering if any one had a template or could just tell me the settings to get best quality out of converting an AVI (divx dvd-rip) to VCD?
Another thing is I have got an avi movie file which is 20 frames per second and I want to convert it to NTSCfilm, but by doing that the video would play on my DVD player jumpy wouldnt it? Anyway of getting around this?
Thanks in advance.
If you want 'true' VCD specs, it has to be a certain bitrate (1150 I think) and resolution (352x240 I think). But if your DVD player will play XVCDs, then you can increase those numbers which increases quality. As far as the framerate, if you are converting with TMPGEnc, set your output to 29fps and turn on '3:2 pulldown'.
some converting questions
By scarlac in forum DVD RippingReplies: 13Last Post: 12th Jul 2009, 08:57 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
Newbie questions on converting avi to mpeg2 and dvd authoring
By mlcampbe in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 14:08 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54
