Hi all,
I have about 30 VHS tapes that I bought while I was in the US and now I am in Australia. I'd like to convert these VHS tapes to DVDs. The problem is that the VHS tapes are NTSC. My VCR is a multi-system that it can play both NTSC and PAL tapes. But the problem is that when I connect it to the digital passthrough on the DV cam, which is PAL, and then my PC and capture the video using Ulead VS 7 I can only hear the sound but no picture.
Would there be a way to get this problem solved? Thank you very much.
Regards,
FLD.
Instead of using the digital passthrough, try recording to your camcorder through line out on VCR to line in on camcorder.
Then just send the DV into th PC through firewire.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Thanks, racer-x. I'll give it a try.Originally Posted by racer-x
Capturing Hi8 video using Sony TRV320E D8 (PAL) camcorder distorted audio
By lchiu7 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Sep 2011, 17:39 -
Will the Sony Hi8 Miniplayer/MiniDV players (w/ TBC) work for VHS capture?
By DaveP56 in forum Capturing and VCRReplies: 1Last Post: 6th Feb 2011, 16:38 -
NTSC Camcorder feed thru capture from PAL
By INFRATOM in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 29th May 2009, 02:17 -
Capture analog video from sony camcorder
By gthoman in forum Capturing and VCRReplies: 14Last Post: 14th Apr 2009, 15:32 -
ntsc tapes pass through pal camcorder into mac for ntsc playing?
By tozier9 in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2008, 18:19
