Hi There,
I Have a Digital camcorder Samsung model VP-D55 ,
The Problem is when im transferring Video from camcorder to application like MS moviemaker 2 or cyberlink powerpreoducer, the transfer always stops before the end of the of the recording, i.e. i can see the progress % going up and the MB's getting bigger but then all of a sudden that info stops changing and no more video is being captured, even thoguh there is more video on the tape, and the tape is still rolling, this can happen after 5 mins or 10 mins or even 50 mins its random. Any help or idea,s
Thanks in advance,
Dosie.
What are you capturing it as? fornat wise and what do you intend to do with it? DVD, scvd vcd.
I havent tried either of those programs for my capturing to avi for conversion to dvd I use windv. freeware and no dropped frames. Also what are you using to transfer it usb, firewire, or maybe a card of some ?sort -
Originally Posted by burdo
in powerproducer it captures the movie but does not say what it saves it as i think its mpg but not sure , as it captures and converts automatically, i then burn it to dvd using "sonic my dvd" software.
Transferring video to DVD
By Special-K99 in forum Video Streaming DownloadingReplies: 5Last Post: 23rd Jul 2010, 08:39 -
Problem Transferring Video Into Computer
By HarveyCee in forum EditingReplies: 1Last Post: 19th Aug 2008, 13:18 -
Problem Transferring Long Play Videotapes......
By TheGMan in forum RestorationReplies: 4Last Post: 14th Jul 2008, 13:27 -
Transferring raw video from Sony miniDV to PC
By TahoeTexan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 16th Apr 2008, 18:01 -
Transferring video to hard drive.
By vid83 in forum Newbie / General discussionsReplies: 16Last Post: 11th Dec 2007, 21:41
