Hi,
I input a *.m2v and a ac3 audio to ifoedit.
It came out to be 4 vob files,
How can I (optional?) have ifoedit to make only one vob file?
Results 1 to 10 of 10
I believe that's what it does make VOB files about 1GB so if the final total file size is 4GB you are going to have four VOB files.
I don't know that look in options to see if you can set the file size. If the file size is 4GB any DVDR may not play in a stand alone player IMO.Originally Posted by rsb
If I've got 3 files with 1GB respectly
I still hope there's any way to make them to 1 VOB with 3GB.
Coz I dont plan to burn into DVD
Only I want to play it on PC.
So too many files trivial me. -
In accordance with the DVD spec, the maximum cutoff size of a VOB is 1 GB.
You could probably find a way to make a 4 GB VOB (somehow) but the likelyhood of that file playing on a set top player is unbeknownst to me. Might play on a rom drive - who knows :P -
If you need/want 1 big file, why don't you make an image with ImgTools and mount that with DaemonTools?This will result in 1 big ISO file.
How can I batch process AVI files and overwrite the originals? Please help!
By DrivesALot in forum Video ConversionReplies: 5Last Post: 21st Oct 2011, 21:59 -
"Could not find any VOB unit in VOB file(s)" - Using Ifoedit
By devilcoelhodog in forum Authoring (DVD)Replies: 1Last Post: 1st Feb 2010, 23:01 -
Exporting smaller files from small avi originals?
By loiseye in forum EditingReplies: 4Last Post: 17th Nov 2009, 18:38 -
Converted avi files darker than originals (avi to mp4)
By Hal05154 in forum Newbie / General discussionsReplies: 3Last Post: 5th Mar 2009, 20:06 -
Create IFO from VOB w/o IFOEDIT?
By theschles in forum Authoring (DVD)Replies: 1Last Post: 1st Nov 2008, 19:19
