I downloaded DVDshrink3.0 beta5 and unzipped it. When i click on the icon i get the following error message window:
"DVDshriink 3 has caused an error in <unknown> DVDshrink will now close."
I have recieved this error when i downloaded a while back. how can i fix this problem? thanks
Results 1 to 11 of 11
Is that a DVD Shrink error message or a Windows error message?
In either case, I know that people don't like expensive solutions, but you should consider trying Windows XP instead of ME and, better yet, a newer computer. -
Also try using the free program End It All 2 to close down all unnecessary processes then run the DVD Shrink Installer.
Do you get the same error if you run End It All 2? How about just starting your computer in safe mode and installing DVD shrink?
DVDshrink error
By rubberman in forum ComputerReplies: 1Last Post: 3rd Sep 2008, 23:51 -
ffmpegX won't install, it gives an error message.
By Anonymous5394243 in forum ffmpegX general discussionReplies: 5Last Post: 8th Aug 2008, 12:50 -
Leopard Install Error
By Lefty! in forum ffmpegX general discussionReplies: 9Last Post: 2nd Dec 2007, 17:42 -
Getting an error on install
By xduckster in forum ffmpegX general discussionReplies: 4Last Post: 3rd Sep 2007, 17:30 -
VOB2MPG 2.5 install error
By stewiegriffin711 in forum Newbie / General discussionsReplies: 7Last Post: 7th Jul 2007, 17:27
