Quick Question,
Okay, so im trying this out for my buddies family, i wanna see if its possible so im doing it for them.
They have all there home movies on Hi8 tapes. There camera is soo old and has no link to firewire or n e thing like that, so ive been wondering how i would get the footage onto computer. If I got one of those VHS tapes where u stick the mini tape in the middle so it will play on a normal VCR and then if i hook up my Sharp HiFi VCR to my computer( I have a ATI ALL IN WONDER 8500 128MB), would that be a good approach??
I thought it would so i decided to bounce it off u guys.
Any input would be GREAT :P
it has a s-video output ... use that
I think that only works if you have a compact-VHS (VHS-C) tape, I've never seen it for 8 mm or hi-8. You may have to find something else to play the tape.Originally Posted by neXus128"Art is making something out of nothing and selling it." - Frank Zappa
I would borrow a miniDV cam with analog passthrough, connect the Hi8 cam to the DVcam with the DVcams AV cable, and the DVcam to the computer via firewire. I did this to capture 8mm tapes and it worked like a charm, I think most people will agree that the covnersion is the equal of any card, plus you don't have to worry about dropped frames like you do with analog capture.
good plan or use a digital 8 which manyu will play a hi8 tape (i just did this) ..Originally Posted by Nolonemo
he had the ati aiw card -- why i suggested the analog route.."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Sony Hi8 has been defective but want to play the Hi8 tape
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 22nd May 2009, 22:06 -
Best Quality: Hi8 to DVD Recorder OR to Pass through to computer ?
By sooner_luvr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 20th Nov 2008, 12:41 -
hi8 to dvd
By jmoore_cne in forum Newbie / General discussionsReplies: 6Last Post: 3rd Jun 2008, 13:45 -
Hi8 vcr, better playback than a Hi8 camcorder?
By Knightmessenger in forum Capturing and VCRReplies: 8Last Post: 22nd Dec 2007, 01:11 -
Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?
By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 06:26
