in new here and i have a question.. I have some high quality mpeg2 files on my comp and their file sizes are HUGE..i need a program that can convert those files into smaller sizes and retains as much of the high quality as possible.. can anyone help me out here? i just need to know what programs are the best. a tutorial would be nice, but i will try to find out how to use the program if u guys cant find a tutorial.. ~thanks
btw: just in case this helps, my mpeg2 files are at least 150 mb in size and im loooking to convert them to anywhere around 50-100 mb.. ~thanks
Results 1 to 9 of 9
You consider 150 MB huge? Uh.. okay...
100gig file is huge ... 150meg is tiny ...
I regularly remove 150 Mb from single frames in movies with
no noticeable quality loss. Of course that depends on the movie
and what you consider quality loss. -
i think 150 mb is pretty big for a 3.5 minute clip.. im not talking about movie files here.. im talking about music performancesYou consider 150 MB huge? Uh.. okay...
You need to re-encode your file at a lower bitrate. The lower bitrate and re-encoding will both result in a loss in quality. Depending on how low you need to reduce your bitrate, you may need to lower the resolution as well because high resolution at low bitrate = crap quality. So low resolution at lower rates may be better, but you need to judge for yourself.
Avicodec will analyze the file and tell you the resolution, running time and bitrate, from there you can select a target resolution and bitrate. I recommend using TMPGEnc and 2-pass VBR for best quality at a small size.
Post the results from avicodec and we can help you choose target resolution and bitrate. (maybe)
"Art is making something out of nothing and selling it." - Frank Zappa -
Now I see. Details always help.Originally Posted by TheRemiX
But now we need to know where you'll be viewing this, player or computer. And let's not forget resolution and source.
I use 352x480 3420k VBR on my DVD player, and 23 minutes = ~700MB. That's about 30MB per minute.Want my help? Ask here! (not via PM!)
150MB for a 3.5min MPEG clip is, say, 5.7Mbps average bitrate. To get this file down to 100MB then you need to lower the bitrate to about 3.7Mbps average. You're going to loose quality expecially if these files are 720x480.
I wouldn't waste effort on this project, just use another disc.
MP4 or FLV High Quality Videos
By gonwk in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2011, 13:51 -
ripping videos from youtube in high quality
By aruwin in forum Video Streaming DownloadingReplies: 16Last Post: 12th Sep 2010, 12:32 -
What's the best program to encode High Quality videos for the ipod touch?
By mikayd in forum Video ConversionReplies: 3Last Post: 21st Nov 2009, 14:00 -
Downloading HIGH QUALITY YouTube videos? Looking for a program to do this!
By Xenogear900 in forum Video Streaming DownloadingReplies: 4Last Post: 30th May 2008, 16:14 -
Free Program to Convert Video Formats for iPod in High Quality
By drstew in forum Video ConversionReplies: 6Last Post: 15th May 2008, 10:26
