does anyone know how to convert a RMVB file to a avi or anything that is a good format?
iv tryed to use a program that converts a RM to avi but it is not RM it is RMVB
try this http://www.newfreeware.com/graphics/2326/
then convert in v-dub"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks BJ_M but that program did not work. all it does is fix the file it does not convert it.
thanks anyway -
Originally Posted by mynameis97rb
it says in its instructions to "fix" it first .. then use v-dub to convert it .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Converting bluray movie files to low size files
By AndreL in forum Video ConversionReplies: 6Last Post: 7th Dec 2011, 02:06 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 29th Aug 2008, 00:33 -
Converting mp4 files to avi files
By HartsVideo in forum AudioReplies: 1Last Post: 18th Jul 2008, 19:20 -
Converting m2ts files to more manigable files
By soledsoled in forum ffmpegX general discussionReplies: 3Last Post: 22nd Jun 2008, 21:49 -
Converting AVI files to Video_TS files/ffmpegx V0.0.9Y OS is Tiger.
By sadepussycat in forum MacReplies: 10Last Post: 2nd Jun 2008, 16:43
