  1. My mother wants to backup the gone with the wind movie, but this movie it is in 1 media but write in both side.
    Then, rip 1 side, later 2 rip ones. The problem I have how burn this movie in media 4.7 Gb, if both folders created contains file with same name.
    Help me
    sorry my english
    Apr 2002
    The State of Frustration
    Click here. And frankly, my dear, I don't giva damn!
    Hello.
  3. I am supposing the movie is divided in two parts, with one part per side, so the complete movie must be bigger than 4.7GB. I think your easiest choice would be first to use DVDdecrypter to rip both sides in ISO mode, then use virtual Daemon to mount the two ISO files to virtual drives, and the latest version of DVD Shrink to reauthor, transcode and stitch together the two files into one file using the source range option.
    Maybe there are other methods but I used this one once and the result was Ok, and the best part is you just need free software to do it.
  4. Member wulf109's Avatar
    Jul 2002
    I converted GWTW to one DVD-R. Rip each side of disk in file mode with DVD Decrypter,each side is less than 4.7Gb's.
    You could use DVD shrink,it's freeware,in it's reauthor mode. Just load side one,then side two. Select only one of the audio streams to improve video quality.
