im looking to buy a capture card for recording digital satalite programs to hard drive to transfer to dvd latter could someone recomend suitable cards
Go here andOriginally Posted by gob14
https://www.videohelp.com/capturecards
now im confused do i need a digital tv card to record sky digital to hard drive or just a tv tuner card with the sat arieal plugged in as i cannot recieve digital tv with a freeview set top box
Well I live in the USA and here you would normally use the ANALOG VIDEO + AUDIO outputs of your digital cable box and/or digital satelite box to your capture card or capture device.Originally Posted by gob14
That means you will have to use the standard inputs on the capture card/device as opposed to the tuner input so you would use the cable box/satelite box as the tuner.
Basically it's like this ... if you can plug your cable/satelite into your TV and use the TV tuner then you can use the capture card/device tuner otherwise you can't.
Of course I live in the USA so you Europeans may be different in this regard.
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
capture cards 360
By ihazcheezburga in forum Capturing and VCRReplies: 2Last Post: 19th Feb 2011, 20:14 -
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 09:03 -
Help with Video/Capture Cards.
By drsimp12 in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2007, 07:05 -
Interferance on capture cards
By Signal in forum Capturing and VCRReplies: 35Last Post: 13th Sep 2007, 22:26
