Hey everyone........I am sure I got a corrupt file here but maybe some of you know something I don't.
I downloaded a Rar file........pretty big one too. About 800mb. Well when I go to open it with Winrar 3.20.....the most current version I believe, I get an error saying: "the archive is either in unknown format or damaged"
I probably got a bad copy. But maybe some of you know something I don't and can open it up. Thanks for any help.
Hatz
Loves the funeral of hearts.....
Have you scanned all the chunks of that archive to see if it has a virus attached?
Otherwise you may be screwed.Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
Do I just scan it with winrar? Or is there another way to do it.
HatzLoves the funeral of hearts..... -
You would have to can them with your anti virus software. If you don't have any anit virus try http://www.grisoft.com
Chances are that one or more of the chunks is just a few bytes over or under the proper amount, and you will have to find out which ones are bad and try to replace them.
Winrar should let you know which parts are corrupt when you try to extract them.Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
Is it a multi-volume rar file? To recover corrupted multi-volume rar files, you have to get PAR files or PAR2 files, depending on which PAR recover system you are using. SmartPAR and QuichPar are two most popular one.
Do a google search.
Rar player
By jimhoofd in forum Software PlayingReplies: 13Last Post: 24th Feb 2011, 13:12 -
Putting all of my digital photos on a DVD for archives
By hardy in forum Off topicReplies: 3Last Post: 22nd Sep 2010, 14:32 -
.rar to DVD Problem
By RemainsHuman01 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2008, 19:41 -
Menu Archives??
By thatoneguy99 in forum Authoring (DVD)Replies: 6Last Post: 10th Jul 2007, 18:33 -
Problem with RAR files
By crowheart in forum Newbie / General discussionsReplies: 16Last Post: 14th May 2007, 23:49
