DOES ANYBODY HAVE AVS FILE ENCODER?
IT WAS SOMEWHERE ON THIS FORUM, BUT I CAN'T FIND IT.
Please don't use caps.
AVS is the ext for AVISynth files. AVISynth is a framesering program (well dll) you can find it under the "Tools" section to the left.
Also take a look at:
http://www.math.berkeley.edu/~benrg/avisynth-tutorial.html
http://www.math.berkeley.edu/~benrg/avisynth-reference.html -
TMPGEnc and CCE encode Avi or MPEG-2 sources frameserved with Avisynth.
AVS to psudo-AVI via VFAPI (1.05), in a BATCH FILE?
By RogerTango in forum Video ConversionReplies: 1Last Post: 6th May 2012, 01:49 -
AVS File Steps
By sambat in forum Video ConversionReplies: 23Last Post: 16th May 2011, 14:27 -
Limiting File Size in AVS Video Converter
By TJF in forum DVD RippingReplies: 6Last Post: 27th Nov 2009, 14:20 -
Problem opening (.avs) file in virtualdub...
By dominator007 in forum DVD RippingReplies: 16Last Post: 19th Nov 2008, 11:53 -
XVID and AVS Media Encoder
By jwfc in forum Newbie / General discussionsReplies: 0Last Post: 13th Jul 2007, 19:23
