Hi all,
Just wondering if anyone could tell me how to burn a AVI file to a VCD.
I use Nero 6, or do I need additional software.
Luke
Results 1 to 13 of 13
First, convert the AVI file to VCD MPEG-1: Click here.
Then, author it to a VCD: Click here.Hello. -
If it's too large, you could always lower the bitrate to make it fit on one cd(of course that would me lower quality)...I agree w/ zippy, use tmpgenc. It lets you lower the bitrate or if you want to split up the file, after encoding, you can cut it.
or keep the best bitrate and use tmpgenc afterwards to split the vid in two using file open mpeg tools set source and end and save. do this twice for each section of the vid. Make sure you have enough space and dont overwrite your source file
Hi, me again. Just encoded the movie into two fairly small (400MB each) MPEG files. However the quality has been reuced terriably. Is there a way to improve quality of a VCD.
Should I try usng Roxio Easy CD/DVD creator's dvd creator?
thanks -
Originally Posted by luke_503
Is the original source good? After you encode the original file, whats the filesize(without lowering the bitrate)? If you dont want to lose any quality and you can spare two CDs, you could split them up on two different cds...I think 800 MB per CD should be good enough. Like the previous poster said, you could also try svcd or cvd.
lol, me again sorry about this you must be getting really annoyed with me
I have burnt it onto a CD to play on my Samsung DVD-M105 (which says DVD,VCD and CD Player on it) and it wont play. It says the file cannot be read.
any ideas?
thanks -
According to this, it will only play a few cdrs. Try different media until you find the right one.
BTW, VCD means factory compressed, not home burnt...even though they wont play on your standalone, it should still play on your computer with something like windvd or powerdvd. Hope that helps.
EDIT: I just read some reviews of your player and apparently the following work on your player...
Vivastar white CDs
Princo 80 Minute Silver/LiteBlue CDR
Only Cd-r of PRINCO work's
Newbie HELP!! DVD to AVI
By Bolisk in forum Newbie / General discussionsReplies: 2Last Post: 11th May 2010, 23:36 -
Newbie converting DVD to AVI
By nuggett_aus in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2009, 05:31 -
Can someone help a newbie? Need the best device for VHS to AVI.
By basshurtz in forum Capturing and VCRReplies: 1Last Post: 28th Sep 2008, 09:43 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 17:37 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 08:34
