I'm going nuts over this problem!
I've tried to capture some stuff from the VCR with iuVCR and VirtualDub.
Theese are my settings:
* Audio/Compression: PCM
* Video/Format: 640x480 - Video/Compression: UYVY
* Video/Compression: PICVideo MJPEG Codec
* Video/Set custom video format: 640x480 - UYVY - YUV 4:2:2 interleaved
* Capture/Settings: Frame rate 25.000 (PAL)
I'd like to capture in 640x480 since I'm going to make an DivX .avi
When I try to capture the movie in iuVCR I have audio/video sync problem issues. I've tried both "Sync using stream offset" and "Audio stream offset Auto". None of them work for me and that's strange since I managed to capture some VCRstuff earlier with my P2 400MHz using "Sync using stream offset" and with perfect audio/video sync results (I now have P4 2.4GHz).
Also I tried VirtualDub, but there I get loads of dropped frames for some reasons, something I never had with my old P2.
Why?
One more thing. After I've captured the movie in 640x480 format and went to VirtualDub for encoding with theese settings:
* Audio/Full compressing mode/Compression: MPEG Layer - 3 - 44100 Hz, 128kpbs CBR, Stereo
* Video/Filters/Deinterlace (blend)
* Video/Compression - DivX Pro 5.0.5 codec - Encoding bitrate 1000kbps.
* Video/Full processing mode
Then there are black stripes both on the left and right of the picture. I added the Null transform filter aswell with 512x480 (I cutted out 64 both on the left and right side).
Is this the correct way to do it?
When watching the encoded clip in the Windows media player (fullscreen it covers the whole screen correctly). But when playing the clip in the DivX player it has even wider black borders left/right side of the picture if I do not choose TV aspect 4:3, is this correct? Do I always have to choose TV aspect 4:3 instead of leaving at Original aspect when watching the movie fullscreen, or is it wrong by me using the Null transform filter and crop the movie to 512x480?
Would appreciate help in theese issues![]()
Ok, managed to solve the issues myself...
I got VirtuaDub working and the audio/sync issue went fine and no dropped frames anylonger
Only the problem when encoding as I described earlier:
"Then there are black stripes both on the left and right of the picture. I added the Null transform filter aswell with 512x480 (I cutted out 64 both on the left and right side).
When watching the encoded clip in the Windows media player (fullscreen it covers the whole screen correctly). But when playing the clip in the DivX player it has even wider black borders left/right side of the picture if I do not choose TV aspect 4:3, is this correct? Do I always have to choose TV aspect 4:3 instead of leaving at Original aspect when watching the movie fullscreen, or is it wrong by me using the Null transform filter and crop the movie to 512x480?"
Still would appreciate help on this issue -
Forgett about it, I solved it myself by adding the Resize filter to 640x480...
Thanks for your help guys -
LOL.... Do you often have these conversations with yourself?.... good information on the fix though...
encoding after capturing
By krohm in forum Capturing and VCRReplies: 2Last Post: 4th Jan 2011, 11:27 -
Encoding problems
By cdaters in forum ffmpegX general discussionReplies: 8Last Post: 2nd Feb 2010, 19:27 -
Encoding problems
By El Barto619 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2009, 22:32 -
Capturing problems
By dbrunton in forum Capturing and VCRReplies: 9Last Post: 27th May 2009, 13:09 -
Newbie question on Capturing to Encoding
By Lucky19th in forum Newbie / General discussionsReplies: 10Last Post: 16th Jul 2007, 13:09
