Hi,
I have a sony hi 8 digital cam, and access to a mini DV Panasonic cam.
If I capture video from the 2 different brand cameras using Vegas 4, through a canopus OHCI capture card, what codec is being used on the captured AVI ?
Is the codec automatically assigned by eg - Vegas, Canopus or is the codec built into the brand of DV camera ?
Your Canopus card does the analog to DV AVI in hardware. Vegas just transfers the data to disk in the proper format. Generally, the file is set to the Microsoft dv codec in the file (dvsd is the FourCC code, I think). There is really no software codec involved in what you are doing.
You can, however, install and use the Canopus DV read codec (do a search for CDVC on doom9.org).
DV CODEC for VHS Capture?
By enbidia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 140Last Post: 24th Feb 2011, 20:11 -
Anybody used FFDshow Mjpeg codec for capture?
By davexnet in forum Capturing and VCRReplies: 8Last Post: 31st Oct 2010, 00:27 -
Which DV codec does capture software select?
By hollowman in forum Capturing and VCRReplies: 21Last Post: 24th Aug 2008, 13:53 -
searching for a good codec for my capture
By Cazz in forum Capturing and VCRReplies: 5Last Post: 5th Jun 2008, 20:00 -
Video Capture Codec
By ThatOtherGuy in forum Capturing and VCRReplies: 17Last Post: 2nd Jul 2007, 02:18
