I have some DV footage shot at 4:3 and want to convert it to 16:9 by cropping 60 from the top and bottom and encode in 16:9.
I can do this in TMPGEnc easily, however I want to use CCE and AviSynth.
But every time i add the crop commnand I get scambled video.
Does anyone know the correct AviSynth method to achieve the above.
I am using AviSynth2.5.
Results 1 to 20 of 20
Letterbox() would add the black bars, so it would still be 4:3
If you want to crop with avisynth, use crop(0,60,last.width,last.height-120)Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
Originally Posted by Ejoc
opps
He is correct.
Avisynth page http://www.avisynth.org/Don't give in to DVD2ONE, that leads to the dark side. -
Okay, then you'll have to add:
BILINEARRESIZE(720,480)ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Ejoc and SLK001...You are GENIOUS's, it worked like a charm.
Thanks..much appreciated. -
Crop(0,60,0,60)
LanczosResize(720,480)
I would use BicubicResize, or LanczosResize for enlarging. BilinearResize will soften your video too much.Impossible to see the future is. The Dark Side clouds everything... -
Actually mine has a typo in it too, which is sad, since I use AVISynth as my only tool for editing
. That should be -60 for the last parameter, but I still stand by my statement. Per the AVISynth manaul:
http://www.avisynth.org/index.php?page=Crop
Crop(clip clip, int left, int top, int -right, int -bottom)
# Crop 16 pixels all the way around the picture, regardless of image size:
Crop(16, 16, -16, -16)
Crop (0,60,640,360)
If you want to verify, just throw each into a script, drop it on virtualdub, and look at the FILE | PROPERTIES.
Version()
BicubicResize(640,480)
Crop(0,60,640,360)
and the second example:
Version()
Crop(0,60,0,-60)
Both of the above scripts will give you a 640x360 output, cropping 60 from the top and 60 from the bottom. If I used the (-120) as you suggested, I would end up with a 300 vertical, which is not what was needed.
Using the old syntax, you subtract the amount you remove from the 'top', and the amount your discarding from the bottom, leaving only the image are in the middle that you want to retain.
60 - Letterbox
360 - Image Area
60 - Leterbox
Since your removing 60 from the top, and you don't want the bottom 60 pixels, the value you woudl use would be 360 ( 480 - 60 - 60 = 360 ). The new syntax is much easier to figure. Just speicfy the amount you want to crop in a negative value for the 'bottom' paramter.Impossible to see the future is. The Dark Side clouds everything... -
His last argument wasn't -120 , it was (height-120) which would
be the desired size with 60 cropped from both top and bottom. -
It seems like both FOO and DJ are correct (once we got that "-" inserted). The "negative number" syntax works just as well as specifying the resultant width and height (and might even be easier to use - less calculations!).
But anyway, ghosty6 got his problem solved, so case closed!ICBM target coordinates:
FOO, because he placed a negative value there, it automatically assumes the new syntax, which tells avisynth to crop 120 pixels from the bottom. In order to use the old syntax, the last parameter must be either 0 or a positive value specifying the desired height to return, after subtracting the TOP value.
I agree, the new syntax is much easier, both to use, and to describeImpossible to see the future is. The Dark Side clouds everything... -
Well, FOO wasn't describing the actual syntax with the negative number. He was saying that the new height would be "old height minus 120", or crop 60 from the top, then your "old height minus 120" will result in a crop of 60 on the bottom.
That makes sense. I was wondering where that value was comming from
(height-120) IS a positive value.
.....unless the video is a little small
FOO, because he placed a negative value there -
I see what your doing now
. Since you didn't know what the vertical height value was, you implied it in your example. I wasn't paying enough attention. Your script would work once the height was plugged in and the 120 value was subtracted from the total height. It's just a long expression of the old syntax.
True. You can pull the height and width from the clip properties.
It's still easier just to tell it to crop 60 from the bottomImpossible to see the future is. The Dark Side clouds everything...
By MGadAllah in forum Newbie / General discussionsReplies: 53Last Post: 26th Jun 2011, 00:44 -
Top & Bottom border
By burgin in forum Newbie / General discussionsReplies: 1Last Post: 9th Jun 2011, 18:31 -
When 16:9 isnt 16:9. Black bands top and bottom.
By agoldfish in forum Newbie / General discussionsReplies: 2Last Post: 17th Mar 2011, 11:18 -
Top and Bottom subtitles on dvd
By loster in forum SubtitleReplies: 3Last Post: 31st Jul 2010, 23:34 -
Subs in the top and bottom of screnn at same time. (How)
By X_Splinter in forum SubtitleReplies: 4Last Post: 29th Apr 2008, 18:58
