I read a Chinese web page http://www.yesky.com/SoftChannel/72351180872744960/20030324/1658782.shtml on making “Mini DVD” on a SVCD format. I followed the steps but the SVCD only plays from my PC (with Intervideo WINDVD player) but not play from my DVD player (that won’t play DVD-R or DVD-RW.) The TV screen comes out with large color blocks but the sound seems ok.
Here are the steps in the web page:
1. Capture the AVI file at 720x578
2. Import the AVI file to TMPGEnc Plus.
3. Open the template DVD(PAL).mcf then also open the /Template/Extra/unlock.mcf so that you can overwrite the DVD(PAL).mcf settings.
4. Change the Rate Control Mode to CBR and Bitrate to 4000kbits/sec
5. Tick the DeInterlace box in Advance setting.
6. Start converting in TMPGEnc Plus.
7. Process the resulted mpg file with M2-EDIT PRO:
8. In M2-EDIT PRO/Navigator/File/open/mpeg, type in the mpg filename
9. In M2-EDIT PRO/Composer/Edit/Insert, type in the mpg filename.
10. In M2-EDIT PRO/Composer/File/Generate/Sector Size change to 2304.
11. OK to start process the file in M2-EDIT PRO.
12. Burn the resulted mpg file with Nero Burning Rom:
13. Select Make SVCD in Nero Burning Rom and UN-TICK the “Create Standard Compliant CD”.
My questions is :
1. Is it possible to create DVD resolution on SVCD by changing the above parameters?
2. What is the M2-EDIT PRO/Composer/File/Generate/Sector Size change to 2304 doing here?
3. Is there any thing I can change to make this work (of course I want to keep the 720x578 resolution and play it on a normal DVD player).
4. Do I need a special DVD player to play this SVCD like the one that can play the “real” Mini DVD created by Nero?
Thanks.
You can make a 352x480 Half-D1 DVD-compliant video and it will create a CVD (SVCD variant).
I always used 720x480 to create SVCD,it worked on all the DVD players i;ve tested and should work on any DVD player that suppports SVCD.
Given the high pixel count I wouldn't go below 2200 average bitrate.
I'm using DVD2ONE to create SVCD and that preserves the 720x480.
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
High-Resolution VCD/SVCD Stills on the UNIX Command Line
By sterno in forum User guidesReplies: 7Last Post: 20th May 2009, 12:16 -
PAL SVCD - Optimal resolution for preserved aspect ratio?
By Gew in forum Authoring (VCD/SVCD)Replies: 7Last Post: 27th Feb 2009, 14:25 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
16:9 resolution for DVD-R?
By Gaelstrom in forum Authoring (DVD)Replies: 6Last Post: 31st Oct 2007, 04:33
