I have ati all-in-wonder 128 pro agp,and im trying to back up some Vhs tapes,macrovision wont let me,any way around it?
Read this http://www.rageunderground.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=20&t=000045 and you find what your looking for.
Here is a link to the application
http://www.doom9.org/Soft21/Files/DisableATIMacrovisionDetection.zip
To check out the site:
http://www.doom9.org/software2.htm
I hope this works for you. -
I encode from DVD settop players to Divx 4.01 in realtime using an AIW 128 16mb for 1 cd rips with a minimum of time invested for less than DVD quality anyway. I am generally pleased with the results. I have a 'secret menu' APEX and an AIWA DV170 which shuttles from the house to the car. With the macro patch applied to the AIW, I can encode from both players although the AIWA, which IMHO, has a better picture on my TV, outputs still visible horizontal lines while the APEX does not. I can only assume this is because the signal from the APEX has no macrovision blanking and the AIWA does, even though this no longer prevents the AIW from 'recording' the signal. Bottomline is the patch 'works' for 'some' AIWs but a no macro signal is better than any macro signal. Invest in a used P200 with DVD, a hollywood + card and software tweak out the macro. No macro and progressive out = nice captures.
Macrovision Question
By matthewjohn23 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 7th Jun 2011, 16:19 -
Macrovision like NONE OTHER
By blacksheepdownunder in forum Capturing and VCRReplies: 17Last Post: 22nd Jul 2010, 05:16 -
Is it Old or is it Macrovision?
By Tiggerpaws in forum RestorationReplies: 4Last Post: 7th Aug 2009, 17:31 -
Macrovision
By adamrose in forum Newbie / General discussionsReplies: 15Last Post: 22nd May 2008, 21:41 -
Macrovision Help!
By dollydoodledumplin in forum DVD & Blu-ray RecordersReplies: 11Last Post: 24th Nov 2007, 11:37
