Can you not use your own backgrounds for menu's with this program? If not which ones can? Really just looking to put my own background on the menus and nothing else.
Yes, you can use any picture you want for your menu. There is an edit button at the bottom of the menu screen. Do you have a recent version?
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 17:46 -
tmpg dvd author - pal ntsc setting?
By jin007 in forum Authoring (DVD)Replies: 4Last Post: 19th Aug 2008, 15:39 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
About the .srt subtle files and the TMPG DVD Author
By ihmcjacky in forum Authoring (DVD)Replies: 2Last Post: 10th Mar 2008, 11:58 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 19:59
