Ok here's the deal:
I was trying to backup one of my dvds, but there is a VOB that would not rip because of a read error. It happens that this VOB is just an Extra, not part of the movie, so I just skipped over it -- I don't need it. Now my problem lies in the IFO (I believe :P)
Here is the file structure:
Now how do I get VTS_03 to just end after finishing the _01.VOB? Do I need to edit VIDEO_TS.IFO in addition to VTS_03_0.IFO? What do I use? Any tutorials?Code:VIDEO_TS.BUP VIDEO_TS.IFO VIDEO_TS.VOB VTS_01_0.BUP VTS_01_0.IFO VTS_01_0.VOB VTS_01_1.VOB VTS_01_2.VOB VTS_01_3.VOB VTS_01_4.VOB VTS_01_5.VOB VTS_02_0.BUP VTS_02_0.IFO VTS_02_0.VOB VTS_02_1.VOB VTS_03_0.BUP VTS_03_0.IFO VTS_03_0.VOB VTS_03_1.VOB VTS_03_2.VOB }-- This is the skipped VOB (No longer Exists) VTS_04_0.BUP VTS_04_0.IFO VTS_04_0.VOB VTS_04_1.VOB VTS_05_0.BUP VTS_05_0.IFO VTS_05_0.VOB VTS_05_1.VOB VTS_06_0.BUP VTS_06_0.IFO VTS_06_0.VOB VTS_06_1.VOB
Thanks :P
- kisk
Try using IfoEdit 0.96. Open up VTS_03_0.IFO. Highlight the titles sets one at a time and hit "delete plasyback". this might help. It does work when the vob is actually there but you do not want the "Extras" playing via the Menu. Test the outcome on your PC and select the extras on the menu. it should hit the VTS_03_0.IFO and throw a black screen then immediately jump back to the selected option. If all works, then try importing the VIDEO_TS folder into your burning software and see if it will accept it without an actuall VTS_03_2.VOB. If not, process the originall DVD through DVDXCopy so you can get a VTS_03 set thet are about 100k total. THis solution has worked for me in the past.
Is there no way to actually set where the end point of the VOB set is. In this case, make the end point at the end of VTS_03_01.VOB instead of _02?
Missing VTS_02_0.VOB, but do have VTS_02_0.IFO
By bec in forum Authoring (DVD)Replies: 6Last Post: 15th Jan 2010, 15:42 -
Missing ifo
By Kurgan71 in forum SubtitleReplies: 1Last Post: 16th Jun 2009, 01:24 -
One VOB of DVD missing audio, how to correct?
By Olsario in forum Newbie / General discussionsReplies: 2Last Post: 8th Mar 2009, 12:45 -
missing ifo-files
By scio_fantasio in forum MacReplies: 5Last Post: 12th Dec 2007, 23:04 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38
